fibreglass fuel tank...
legoman67
well,
After reading about the grady white and its fuel tank issues i decided to take a better look at ours, havent really looked at it all that much, i only opened it up once to drain the old fuel, which was fine, and not discoloured. Anyways, i opened it up the other day at the pickup fitting, and looked inside with a flashlight, and it turns out the tank is fibreglass. Is this good or bad? it has no leaks, because i just emptied it not long ago, and before that i never smelled or saw any trace of fuel. Should i just leave it to its business?
The boat is a 1974 Carter Safari.
jonesg
Re: fibreglass fuel tank...
Are you the original owner, it might be a replacement tank, I thought they used alum tanks.
Glass is as good as the resin they use, theres special fuel resistant resins for that purpose. Sure its not nylon?
oops!
resin does not like gasoline......most tanks are alum...
BUT....if it aint broke........
mthieme
There's a lot of scuttlebutt about ethanol dissolving fiberglass fuel tanks, sending the resin downstream.
legoman67
no, i am not the original owner, it may be replacement, the guy i bought it from did say the stringers and transom were redone 8 years ago. Maybe the fuel tank was done too?
im restoring the boat. the only thing i am sure is that its not metal or aluminium, it looks like fibreglass. i have heard about the ethanol thing aswell. Its held up this long, so either it is about to go(knock on wood), or its not going to go...
