filling holes
abbotm5
So it turns out Force 96 outboard mounts are different than 91 outboard mounts. What is used to fill the old holes? Any tips for drilling new holes?
JB
Re: filling holes
Get some 1/2" dowel. Cut a piece about 1/2" shorter than the depth of the hole and epoxy it in the hole with about 1/4" countersink at each end. Then fill the 1/4" with a good epoxy filler.
For new holes I use a gadget called a Portalign to keep my 1/2" drill exactly perpendicular to the transom surface.
