Filling Holes
mike_i
I'm going to remove my transom mount transducer. I don't have any 5200 can I use marine grade 2 part epoxy to fill in the holes? I was thinking of gobering up some toothpicks with the epoxy and packing the holes. Is that better than trying to fill the holes with just epoxy?
mix up some marine tex epoxy putty and mush into the holes
airshot
When filling screw holes, I always put a screw into the hole along with sealant, especially if the hole goes thru...what would happen if the sealant popped out of the hole ??
dingbat
To repair transducers holes, I use stainless, flat heads screws the same size I removed.
Countersink the gelcoat deep enough to put the screw head roughly 1/8” below the surface. Coat screw with epoxy (MarineTex) then screw in hole. Fill countersinks with white MarineTex. Let dry then sand and buff out.
mike_i
Thanks guys, I never thought about the screw thing.
dont think screws are needed if the transom is dry. however they dont hurt
mike_i
I was going thru my epoxy stash and found a brand new tube of JB Weld Water Weld. Is this stuff as good as the marine tex?
