Filling Hollow Pontoons with Foam
badboymonk
:confused:My pontoon boat rides a little too low in the water and was wondering if I filled the hollow pontoon floats with foam, would it make it float higher?
Shamus O'toole
Re: Filling Hollow Pontoons with Foam
I could be wrong but I would think filling them with foam would add extra weight making it ride lower in the water.
bitterboater
Any thing you add to a boat will add weight to it.
Have you checked for drain plugs in the tubes? Possible cracks or separations might be causing water intrusion.
crspang
+1
Added weight = lower ride
To the op, two options to achieve a higher ride are lesson weight on boat or add a third toon.
