I finally got this 60hp to run, it's a 1995 oil injected 60hp Bigfoot Merc. Compression is good on all 3 cylinders, around 125-130. I changed the plugs, drained the gas and got it running on a high dose of sea foam and gas in the tank.
Now I have three additional concerns:
1) Once got I got it to start up, I hooked it up to muffs and let it idle for 20 seconds. The tell-tale wasn't spitting so I filled up a half cut 50 gallon drum and got the water to about the skeg. Again., it started right up but didn't spit. I went back to the muffs and compressed them while the water was on and noticed the tell-tale was pushing a stream, this was with the motor off. I grabbed some clamps and locked them on the muffs and started it back up. The stream didn't get any faster.
- Does this mean the water pump is bad? Would the tell-tale spit just due to pressure of the water being pushed through it?
2) While the motor was running and water was coming out, I put it into forward gear. As I was putting it into gear it made a clunky noise.
- Not sure what this means but it did it when I put it into reverse to.
3) I hope someone is still with me
. So my last issue is that while I had it in gear for maybe 1-2 minutes I noticed the water coming out the tell tale was very hot, I immediately turned the motor off.
- Could this be a thermostat problem or something else?
I really hope I didn't land my self a crap motor but after being excited I got her running, I'm a bit disappointed again.
