Finally I tested the Solas Scorpion Prop!
LubeDude
Went out fishing last evening and thought that I had better test this prop you sent me last winter. Sorry it took so long.<br /><br />Anyway:<br /><br />Its a Solas Scorpion 15 1/8" 25P Very High rake prop, [I had to remove the trimtab]. I run a Hi-Five 25P prop most of the time, Im unsure of the dia., but ita probably about a 14". It turns about 5,700 RPM at 53-54 MPH at WOT and I have to back down about a click on the trim for max bite. It has great hole shot. I also run a 15" 25P Turbo four blade that is just a bit slower out of the hole and it runs 54-55 MPH at about 5,500 RPM @ WOT and with the trim about the same.<br /><br />Tested with fully loaded boat with two people on board:<br /><br />This Solas prop is very smooth and I have no complants with the way it feels once on plane. It hooks well in turns, really carries the nose well and I can trim the engine more going slower with out porposeing than any prop I have ever tried. However, its just a bit too much prop for my needs. It was a pig out of the hole, Max RPM was only 5,400. Top speed was 57 MPH. Id like to try the same prop in a 23P. I actually got the last two miles an hour buy trimming down more than I normally have to, so it would seem that it doesnt like being too far out of the water. But it is a three blade and Im comparing it to props with more blades. Like I said, I really like the prop, its just a little bit too much prop for my application. <br /><br />I think that if I were by myself, and with an unloaded boat, [I probably had over 50#s of tackle bags in the front of the boat]. it would be 60 MPH prop.<br /><br />Thanks Kenny for the loan of the prop, Ill be sending it back soon.
walleyehed
Re: Finally I tested the Solas Scorpion Prop!
Great info LD, thanks!!!<br />BTW, the holes in the prop are just pilot holes...they are meant to be drilled to suit the application, which may have helped hole-shot, and yes, it's the highest Rake prop I've ever seen, and also, it IS available in 23P.<br />I find it interesting that it pulls harder than a 4-bld 25P Turbo, yet is quite a shake faster...<br />Gaining 2-3MPH at 100-200 less RPM equates to high efficiency..
LubeDude
I like the prop so well, I would buy a 23P from you!<br /><br />Email me. I had a harddrive failure, and lost your Email addy.
walleyehed
LD, I sent my email addy so you have it, but as for the prop, look into the iboats prop finder and you should see the 23P.<br />These people are taking good care of me, and I want to take good care of them...<br />If you can buy it here, please do, and thanks for the Help, LD...excellent info!!!
LubeDude
Thanks, didnt know and will do. :cool:
Ron G
Hows the bow lift with the scorpion?
