riponfisherman
- Jul 24, 2010
- 7
Over winter a bought a 1992 Ebbtide Dynatrak bass boat. It did not have a finder mounted on the console, only one on the bow mounted to the trolling motor. I bought a Lowrance M52 GPS/chartplotter to put on the dash that would read from the rear of the boat. The only problem is that im not quit sure how to mount the transducer. The boat has a 150hp so I need it to be able to read at high speeds, which would indicate mounting it inside the hull, but I would also like it to be more accurate and would like the temperature reading to work when im bass fishing. What would be the best way to go about this? Would it work to buy a cheaper finder like a Lowrance X-4 and mount that in hull to read while driving and then switch to the M52 mounted on the transom when fishing? Any advice would be greatly appreciated. I have 2 pics of the transom attached.
