bob johnson
- Feb 25, 2009
- 4,306
does any one know of a company that makes larger dia props for the small gear case V4's
mine is a 1995 60 degree looper 115 johnson.
I cant find a prop larger than 14" that has a HUB that matches the small V4 gear case.
i had been looking at the props with the HUB kits thinking that any would fit once I have the Hub kit...but the old codger mechanic showed me the difference yesterday...the HUB outer dia is 1.5 times as big on the large V4-V6 gear case...
so even though the hub kit fits the HUB DONT!!!
the very end of the prop fit inside the ID of the lower unit!!!
I have enough room under my cavitation plate for a 16" dia prop!!!!
but with the 13 spline prop shaft and gear case...14 is the largest so far i have seen.
Id like to find a 14-15" X16 prop!!!!! in aluminum..
or a four blade aluminum in 14-15" X 15 prop
bob
bob
