Firing issues.
russm
An old blue band 115 merc. Took it out last year and it was bogging. Should have known it was the fuel pump. I had cleaned the carbs and it ran perfect on the hose. While trying to get up to plain I turned the trigger slightly and the engine died. Now I have no fire. I know a place in Huntsville to check/rebuild the power pack and trigger. Amm I missing any other possibilities ? Thanx
Chris1956
Re: Firing issues.
Russ, If you go on the CDI.com web site, they have a toubleshooting guide for your ignition. I will guess it is an ADI ignition with six coils and two switch boxes.
