Firing order 4.3 1990 help
acuraguy81
Any one have the firing order for a 1990 omc 4.3. And the distributor wire locations? Please.
Don S
Re: Firing order 4.3 1990 help
1-6-5-4-3-2 is the firing order. The location of the #1 wire depends on where the rotor is pointed when the engine is brought up to #1 TDC on the compression (firing) stroke. The rotor should turn clock wise.
Bt Doctur
Try to keep everything on 1 post, dont start with a new question
1-6-5-4-3-2
Front of engine
1 2
3 4
5 6
Dist
