Firing order on Chrysler 135
bob880
This may be a dumb question but i will ask it anyways. Is there any certain way that the spark plug wires are installed?
how do I know what wire goes to what plug i guess is a better way of asking. I got a different distributor can and just want to make sure I put it on correctly.
Thank you in advance,
Bob
jimmbo
Chrysler engines were rarely seen where I boated so my knowledge/experience of them is slim to almost none, but...
1-3-2-4 is the firing order. You really need to get a service manual for you model of engine to guide you through the process of finding TDC on cylinder No.1, setting the timing pointer at 0 degrees, then moving flywheel until a specific number or letter on timing pointer aligns with specific degree mark on flywheel(may vary depending on year), etc, etc
