Started getting my 3.7 merc ready for the season and at first it would turn over but never start. Put spark tester on and had no spark at the plugs. Checked distributor cap and it was burnt at all the contacts. Replaced it and cleaned all electrical connections and boom she fired right up. Only problem is it was as if i had it at full throttle. I shut it down quick. Tried again, same thing. Tried total of 4 or 5 times and stayed the same. When i originally tried to start before changing the cap i sprayed starting fluid down the throat of the carb. I did this maybe 3 times. So now i am wondering if it is the starting fluid still in there causing the rpms to jump or if it something else. Any thoughts on this?
