First impression of a Solas Amita 4 blade aluminum prop
98Shabah
Just thought i'd share my experience here. 1998 18' bowrider, 3.0L 4 cylinder, Alpha One Gen II, family of 4, beach gear, full tank of gas (30 gallons). Prior prop was a Michigan Wheel 21 pitch 3 blade aluminum in excellent condition, boat was pretty slow to get on plan, wouldn't pull me up on a wakeboard (it wouldn't plane), and top speed was 38mph at 4600rpm but if I trimmed out all the way it would porpoise. I purchased a Solas Amita 4 blade 19 pitch, with the same load as before the boat quickly gets on plane at 17mph and holds it, top speed is 38mph at 4800rpm (didn't stay there for more than a couple seconds!), and it no longer porpoises.. Also, in turns it is much more "on track", idle speed in gear is slower and it's much more controllable at idle speeds, and I must say, that 4th blade makes the propulsion as smooth as a Cadillac. Haven't had a chance to try wakeboarding behind it yet but so far I am VERY impressed with the improvement in performance.
machz1000
Re: First impression of a Solas Amita 4 blade aluminum prop
great to hear i just ordered one i am currently running a solas 3 blade 21 pitch and am overrevving a few hundred rpm and have ordered a solas 23 pitch 4 blade hope to drop a few hundred rpm and pick up a mph or 2
Lucky_twin
have you had a chance to try wakeboarding behind your boat with the 4 blade yet? I am looking for a new prop for a very similar boat.
thanks
steelespike
Hope the 23 isn't too much just going to a 4 blade usually usualy will lose 100 to 200 rpm. and a 2" pitch change usually nets 300 to 400 change.You should still get the normal improvements.
98Shabah
thanks
Just got back from a week at the lake, the new prop gets me out of the water easily without even having to go WOT... It's like it gained 100hp. lol.
