vroom ZOOM
- Aug 15, 2017
- 427
got this mercruiser 2.5, found a drive for it, but the U joint on the top is a bit rusty. before I buy the drive, is the rust on the u joint a serious problem or not? the drive apparently worked well until something happened to the engine. the prop is on it and doesn't seem to have any damage.so should I go for it? also, are there any other things I should watch out for on the 2.5 mercruiser? thanks.
P.S. looked at the bellows, they seem to be ok, and the metal engine parts (or maybe its the gimbal bearing) down in the bellows have one very small slight surface rust discoloration. is that a sign that the bellows are leaking?. I would think that if they where leaking the whole part would be covered in rust.
