handirifle
- Apr 29, 2011
- 30
Let me start off by saying I found this forum out of frustration, probably like a lot of folks. I have a '72 6hp Johnson, and have been having a few "issues" with it of late.
The motor has sat for a year or so, since I last used it, due to moving and building a new home, yada yada. Anyway, I've been too busy to get the boat in the water until a few weeks ago. Long story short, it didn't run worth a darn. After doing some trouble shooting on my own and bouncing ideas off friends, I ordered a carb and fuel pump kit.
I do not have a manual, so am winging some of it. Some things I know real well on engines, some not. The issues with this engine are definitely fuel supply problems. That solved, I did the carb today, and got it all back in fine order. Wasn't sure on float setting, but have since found out what I needed to know there. I will double check that tomorrow.
I think my current problem, is the fuel pump. The motor starts, runs good, than slowly runs out of gas and stops, and then is tough to restart. It MIGHT be the float setting, so I will check that out tomorrow, for sure.
I had put a kit into the fuel pump, but like a few that I have read here, they are a bear to put back together. Luckily, after doing a search, i found this link posted http://www.sschapterpsa.com/rambling...g_fuelpump.htm on one of the threads. PERFECT, just what I was looking for, and will take the laptop to the shop tomorrow, and follow the instruction, step by step.
I anticipate a good running motor when all is done, thanks to this forum. I WILL follow up the post after the work is done.
