'88 alpha 1- 350 first time in water in 11 years.new lower shift cable, grinds when going into reverse but seems to go into fwd fine, could it be a bad interupt switch? i noticed no stumble in the motor when shifting
the other problem i had was 200+ temps and im not sure how to read the symtoms witch are: hotter at lower rpm, manifolds that are cool enough to be touchable. i know the impeller is pumping (i have a section of clear pvc tubing going to the heat exchanger) thanks-Russ
