BB63QM
- Aug 4, 2023
- 78
My project boat went live this weekend (Glaspar 150 Cutlass with mid-70’s Mercury 850 Thunderbolt)
Problems:
1. Could not find reverse. Back on land, discovered that the shift cable was coming up short, so spun the adjustment once and now shifts fine (manually, on land)
2. Shifting hard to forward. Maybe too high on the RPMs? I have it idling between 800-1000…can’t get it smooth under that.
3. Part also may be the controller (ancient MerControl)…getting off the detent is less than smooth leading to either a granny shift or a heavy clunk, and with the RPMs at their minimum, lots of stalls as the prop engages. In order the avoid stalls l, I resorted to hole-shots or quick acceleration after the shift, but that isn’t ideal in close quarters.
4. Not cold-starting without Starter Fluid (usually fine with the key once all warmed up and fuel flowing. Maybe I just don’t have faith in the wild (flop-sweat, all eyes on me, and worrying that I’m going to run the battery down chasing a start…at home I usually test on the charger, so that’s not an issue)
5. TellTale is not flowing a lot. Plenty of water circulating in the motor, not overheating, blows water on muffs, but tell tale usually tricked and sometime flow, but never flows hard. Is that a symptom of something other than perhaps a clogged telltale? (I recently broke the plastic tell tale connector at the power head, as of replacing that a month ago, the tube was clear from there to the outlet on the other side)…could there be a clog inside the power head?
6. couldn’t get on lake1…failed Mussel inspection due to rain water in the bilge due to clogged drain and test/muff water in the lower unit. They are strict and require a completely dry boat at some CA lakes. (Better cover during weather, better drain checks, muff testing day before, not morning of)
7. Fuel gauge not working (electrical issue to chase)
Successes:
1. Gets up on plan nicely
2. Rides smooth at all speeds.
3. Really rips…don’t know how fast we got it, but we found out what was tied down and what was not. Spent most of the afternoon at 4500+
4. Good steering at all speeds.
5. Handled parallel and perpendicular wakes well (no loss of control)
6. Nice day with the family on the lake.
Any advice is welcome. You all have been a big help throughout this project.
Problems:
Successes:
