Re: first time boat owner
Hey snic68, welcome aboard! You picked a great place to come for info. Alot of very knowledgable boat owners and industry pro's here. Even though I'm neither, I'm glad to share the little I DO know!8)
First thing you need is a good manual! It's NOT an option if you're going to do any work yourself. Even if you are familiar with automotive mechanics, marine mechanics is a whole 'nother animal.
Of the top of my head, and not knowing the previous maintainance history, here's what I'd do:
Remove any old gas and flush the fuel lines with fresh stuff.
Pull the float bowl and clean it and check that all the little passages are clear. Check the float and needle/seat. Clean/replace any fuel filters & water seperators.
Replace any regular tune-up parts like plugs, wires, points, etc.
Change the engine oil and filter.
Remove and check t-stat housting passages and t-stat.
Pull and check manifold passages, especially if RWC or used in salt water.
Replace all rubber (hoses, belts etc.)
Replace Impeller.
Change oil in outdrive.
Check all electrical connections for corrosion/tightness, especially grounds.
Check battery electolyte levels for dead cells.
I'm sure there's more, but that should be a good start. People alot more experienced than I, and familiar with your particular setup will probably have more specific things to look for.
Some things, like belts and hoses, can probably be left while working on it on land, but I'd replace them before going out on the water. I had a rubber manifold coupling that looked/worked fine on land, but blew the first trip out. That few extra dollars in rubber is worth alot in peace of mind!
Say hello to the wonderful world of boating and goodbye to your disposable income! :devil:d
