Putzaroni1
- Oct 20, 2012
- 108
So I've used Frank's timing fixture that I purchased before to set points and it works awesome. On this motor though it was missing everything on one side of the ignition so I decided to replace both side coils, condensers and points and have never done that before. Everything is in place now and I've removed the wires from the condenser and the coil to set the points. When I put the fixture on and ground the one wire from my meter to the armature plate, I put the other on the screw that ordinarily holds the condenser wire and the coil wire to the points. It does not have continuity when the points are closed. When they open it should be an open circuit but when they are closed I should have continuity. Am I missing something.
Is there something I did wrong with installing all of these components. They are the standard Sierra Tuneup kit for a 1969 6hp Johnson.
I'm sure I'm missing something but when the points are closed, there should be continuity, correct ?
