Re: Fish Finder Interference
jhib
With Humminbird and I am sure others may have the same issue. First if it is engine is when you are out on the water, go to neutral and rev it a little bit (do not over rev) and see if is affecting the screen.
Most of the time the interference is electrical noise and it can come from the power source and sometimes the routing of the transducer as dingbat stated.
What you may want to do, depending on how much trouble it is, take the power source, run a set of temp wires across the deck away from everything and connect directly to the battery. Then likewise take the transducer wire again across the deck away from everything and connect to your bird. If the issue goes away it is one or both of them combined. If it is electrical coming from the engine you can purchase and install chokes on the positive wire.
I have had very little noise when running the big motor, the trolling motor has caused a lot of noise.
George
