Fishfinder location
Dick Sorensen
I am planning on installing a Hummingbird Matrix 12 unit in my 20 foot cuddy....I have easy access to the bow area via the v-berth....is this is good location or should I install it in the bilge under the engine.... what are the pros and cons.
HONKER1
Re: Fishfinder location
My limit knowledge would say NO. If you are running with the bow up, or heavy waves are bounceing you around, you won't be getting a reading. Fish finder/depth finders don't work to good when shooting through air.
mthieme
I can't think of any exception where I have seen a transducer mounted anywhere but the stern.
mudslinging79
i have heard stories of the tranducers mounded on the bottom of the boat being ripped off in a careless moment while launching, loading the boat. i asked a few boat shops before mounting mine, and they all say to mount it on the stern
Mark_VTfisherman
I assume you were referring to an installation that "shoots through" the hull. I personally like that approach- nothing to collect weeds and no holes through the hull.
The best spot, as mentioned by another poster, is in the stern- you can't guarentee good reading at speed with anywhere else. The bilge can be a good spot, I would pick that.
But in the same way that mounting forward in a planing boat can create issues, you have to mount the puck in an epoxy bed to insure the transducer can send its pings directly into the water column- no air space, no bubbles, no plywood, no foam...you might already know that. Certain kinds of fiberglass layups and/or plywood in the hull between the puck and the water will cause the transducer not to work. My fishing buddy has an 18' Nitro with a shoot-through transducer that won't work right unless he lets a little water into the boat. That was a dealer-installed unit! Sometimes it happens.
You don't mention what brand your boat is but it is likely someone here can tell you if shooting through the hull will work in your particular boat.
