Re: fishfinder transducer
I would assume that if you mounted the transducer straight to the bottom, you will not have side scan ability anymore. It would have to be set against the side of the hull to operate properly and that position will have to be below the water line. BUT, I would contact the manufacturer for proper installation to be absolutely sure before epoxying any transducer(s) to the inside of your hull... JMHO!
