Re: Fitting Perfect pass system ? (or
Mine took about 1/2 hour to install. The most difficult part was ensuring that I had the tach signal properly connected to the StarGazer control box. The satellite receiver just goes on the dash, usually, and the control box mounts under it. On the engine there is a servo that works the throttle and an addition to the throttle cable. You can run with it partially installed if you get stuck on something so you need not worry about losing any boating.
Plan on more time than I took. That way, if it takes over an hour you are fine and if it takes less you can have a beer.
