Fixable? or Replace it
chrisgo1128
Hello,
I bought an older boat as a pass time project, in the process of cleaning up /repairing the engine and one of the exhaust manifold has a crack in it, it dosent look super bad, also looks like whom ever had the boat before tried to fix it.
(i removed most of the JB weld)
Would of taken better pictures but my camora battery was dead : / so used the phone, here's one more view of the same crack
Wondering if it would be fine to just remove the rest of the JB, grind down the extra metal from the last "repair" put some new metal there to seal up the manifold and call it good? assuming its not leaking, or just find a replacement that'll work?
Thanks for your time :)
Re: Fixable? or Replace it
Ayuh,... That looks like an old Batwing manifold,... They were Junk when Brand New...
Replace it...
Up-grading to the 2 piece units is the Best way to save your Motor...
floater180
JB weld only worked for me on 3 trips but ended up buying a good used set.
bomar76
Trash.
Not worth the time you spent cleaning it off.
Toss them and replace....BOTH
