Fixed orfice tool substitute
Gradywhite3535
Hi all, I found a video on YouTube where a guy uses a special tip screw driver(looks like a flathead) for taking out the fixed orfice on a 1976 johnson 6hp. I know evinrude makes one but id rather not have to spend $50. I put the link to the video and he shows it at 3:13. If anyone knows of a substitute or knows where I can find a tool like this please let me know... Big thanks
http://youtu.be/-aWICvsQZQ8
F_R
No Title
I used to make and sell some, but no longer do. It is surprisingly difficult to make a screwdriver. If you want to have a go at it, start with a screwdriver with a (exactly) 3/16" round shank. Cut off the end, square. Now grind or file two flats. This is important and what makes it "special"---The flats must be parallel to each other. If tapered like an ordinary screwdriver, they will tend to spread the soft brass orifice plug, making it harder than ever to remove. Or impossible.
Gradywhite3535
Sweet thanks F_R, thanks for the tip. Would it be possible to take a pic of the tip facing the tip from above so I can see it better?thanks and if anyone knows of something I can buy I would apptiacte it... Thank you again
Big Gee
You might also find a 3/16" hollow ground screw driver works.
F_R
No Title
Here are some OMC ones. Except the stubby one is one I made for removing the jets on a V-4 without removing the carburetor.
Gradywhite3535
Thank you guys so much, I really appricate your posts back... I bought 2 screw drivers today... One That's 3/16 that I will try to grind down to the shape and another 3/16 that is a slotted cabinet tip... Thanks again
interalian
My home made special tools, left to right: piston stop to check TDC timing mark, jet wrench, piston ring clip pusher. Cost approaching $0.
Faztbullet
Go to Ace hardware and get their small straight edge screwdriver...its perfect for jets and are sold separate($3). It the first onre in pic......
Grub54891
I use a pair from a gunsmith set, they have nice solid shafts, and the tip is flat and perfect for the jets.
