Re: fixing grease fitting for gimbel bearing?
Maybe you could just replace it with a threaded plug and then only install the grease fitting when you need to pump in the grease. Or you could go to a larger threaded or pressed-in grease fitting, or you might could JB Weld your fitting in place. Good Luck!
