james__12345
- Jun 26, 2012
- 196
When turning the throttle on this motor, the shaft that goes up into the motor doesn't turn untill the rest of the system has moved quite a bit.
The two gears with the black arrows turn together with the handle, but the control lever with the red arrow doesn't. In the opening in the throttle control gear with the blue arrow, you can see the control lever slipping inside that joint.
I'm thinking it might just be the pin. The pin does not come out into that opening in the gear like I would expect it to. Does anyone have a close picture of the opening in the throttle control gear (blue arrow in the second picture) so I can see how that pin should look, and see if it is sheared off like I'm thinking it is?
