Fixing sagging headliner or replacing...
Alwhite00
Master Chief Petty Officer
Not sure where to post this - Feel free to move if needed.
Anyone have any fixes for a sagging headliner in a mid-80's sea ray? It has the "monkey fur" headliner material - Good shape, Just sagging. Where can you buy this stuff?
LK
Failproof
Re: Fixing sagging headliner or replacing...
3M spray adhesive. Designed for headliners. Peel off, spray on adhesive, replace headliner, and away you go.
rallyart
Yep, the 3M stuff is great and easy.
smokeonthewater
if it's a small spot you can also cut a slit.... spray 3m and put it back..... do it right and it's nearly invisible
25thmustang
That headliner material is not cheap, and if you plan to do one part, plan to do all of it. Not sure the size boat you have, but that can get expensive and be a real pain (it's usually installed prior to walls, cabinets, etc). I would go the adhesive route like stated above.
