nola mike
- Apr 22, 2009
- 5,555
incredible how the problems keep adding up! just when i think i'm about to be back on the water...anyhow,
engine turning over, would catch, then immediately die. fuel in the carb, and i was getting spark as well. HOWEVER, with the key in the "on" position, i had 0v at the coil (+). no voltage to the purple wire at the choke. all my gauges worked, so i figured the problem was at the wiring harness. when i went to disconnect the harness, the #5 (purple) pin became disconnected. i suspect this was my problem. it isn't obvious to me how to replace the pin in the boat side of the harness--doesn't look like it was crimped/soldered in there before. should it be? looks like it would be much easier to just jump the wire to the choke connection, but i hate to half-*** wiring. makes future troubleshooting much harder.
and why was i getting a spark when cranking? hard to tell from the wiring diagrams, but does the slave solenoid provide 12v to the coil through the pur-yellow wire when cranking for a little extra oomph?
