fixit6219
fixit6219
1984 Merc 150 XR-2 after replacing impeller with a new kit and the two t-stats, the poppet valve has been checked and deemed ok but, the motors pees strong and seems fine, but it is overheated with almost scalding water temps as it comes out. Motor overheating upon getting on plane and beginning a run.
I dont know what else to alter or change to correct this problem.
Any suggestions would be appreciated
Thanks
fixit6219
fixit6219
overheating still after new impeller kit installed. water is almost scalding after cycling and alarms sound for overheat upon getting on plane. what to do?
Chris1956
Re: fixit6219
Remove and test the thermostats. If they are NG replace them. Retest. If it still overheats, rebuild poppet valve.
