Flakes of rust inside freeze plugs
surferguy001
Its been several years since i have posted here or worked in rebuilding my Chevy 350, but i gound some time today to get the last pueces if the engine stripped off. I took the freeze plugs out too because i was going to have the blocked boiled and cleaned to remove the small patcges if rust. When i removed the freeze plugs there were literally flakes of rust looking stuff falling out. I am not sure if the block is still good now; what do you guys think.
I forgot how to upload photos so if someone can remind me how i will post of photo.
Thanks all
cr2k
Re: Flakes of rust inside freeze plugs
Fine, you will always find this.
MarkSee
For a fellow SoCal guy, of course.
Click on the 'go advanced' button then look for the 'paper clip' icon which is just to the right of the smiley face;it should say 'attachments'. Click on that.
Then in the next window up at the top right you will see the 'add files'; click on that.
Then click on 'select files' then browse to the location of the file. There are limits on size of the files.
Mark
surferguy001
Mark, your from the IE! I forgot to change my location, I'm in Woodcrest which is just down the street from you!
MarkSee
91 @ Serfas Club is my area. We've been here since '92; wife lived out this way since late 70's.
I'm not an engine guy so can't comment on the picture but nice to have a new IBOATS neighbor.
Mark
achris
More fish than mountain goat
You're in California, I assume you use the boat in the Pacific. That rust is normal for a saltwater engine....
Fun Times
Mark
Howdy IE neighbors, I'm in the Moreno valley area myself!:)
Mark, i'm betting you must eat out a lot since you're so close to In-N-Out Burger.:D
Thanks all
Ayuh,... It's completely Normal...
MarkSee
Lake Perris is your backyard pond?
I-N-O does sound good right now...animal style fries....and it's only 5:40 in the morning.........
Mark
gm280
Totally normal. Considering the thickness of cast blocks, there is still lots of good material in that engine. Have it boiled out and rebuild...
