Ok here's the story. I hope someone can lead me in the right direction. Last year I purchased a Four Winns 170 Freedom. We have had multiple problems with the boat but the one that has not been fixed is the trim gauge. Sometimes the trim gauge will work, sometimes it doesn't. We have had the boat in three times for it. They replaced the gauge, sending unit and cable (from sending unit to gauge). The shop seems to be full of slackers so I don't know if the cable was actually replaced. When the boat is out of the water the gauge seems to work fine. Most of the time the gauge is pegged showing the trim is all the way up when the trim is down. Sometimes if you turn the steering wheel you can get the trim gauge to register and if you hit just the right wave the gauge will also register. This leads me to believe that there is some sort of wiring problem (short). Most of the time the needle is just bouncing around. The gauge seems to work best at full throttle. If the boat is out of the water it seems to work except when I am turn the steering wheel back and forth. Does anyone have any suggestions? Seen this problem before? Know the right part of the boat to kick? Any suggestions would be appreciated. Thanks
