Flame Arrestor bolt too long?
simbey1982
So i was address an accelerator pump issue when I was putting the bolt that holds the flame arrestor on. I noticed that as i tightened it down the throttle linkage moved. I then took the flame arrestor off and threaded the bolt. It is long enough that it is holding open the throttle body plate. This doesn't seem normal am I wrong on this or is the bolt too long.
Ayuh,.... Welcome Aboard,..... That's usually a stud, 'n nut, not a bolt,....
'n yes, it shouldn't be that long,....
southkogs
You can kinda' see mine in this shot:
If that helps a little...
Silvertip
Threaded rod + jam nut then flame arrestor then wing nut. Or a trip to a bone yard to get the correct stud. One end will have only 1/2 inch or so of threads to limit the distance it can be threaded into the carb. Or just get the correct length bolt.
