Re: Flat boat prop questions
Does 18 X 60 mean an 18ft long boat with a 60 inch bottom width?
It would take a 26 pitch to go 54 mph at a 10% slip using your motor's 2.0 gear ratio at 4900 rpm.
Gotta love those speedometers. :facepalm:
Verfify your prop size and rpm, and we can calculate how fast your boat can theoretically go. They generally go a little slower than that in the real world.
But the bottom line here is that your motor rated hp is at 5000 rpm. That means it's doing all it can at 4900 rpm with whatever pitch you're running now.
If you want to go 60 mph, you'll need a BIGGER motor(or possibly a better prop). What's your boat rated for? And what kind of prop are you running now?
