Fleetwin 7.5
MatthewK
My 1954 Fleetwin 7.5 is getting water in the cylinders. I did a compression check and it reads approx 60lbs in both i don't know what the spec is for that engine though. Also i removed the powerhead and there was a cork washer that was on the bottom around the crank shaft that was all stretched and worn out. Could this be the source of the water? Where should I go from here?
D
DJ
Guest
Re: Fleetwin 7.5
Matthew, <br /><br /> Yes, that could be it. But, I would replace the head and exhaust cover gaskets as well.<br /><br />The compression is-OK.
