float adjustment on 1976 mercruiser140
deck hand
I just bought this boat and have been having trouble. I noticed that there was gas coming out of the tube that comes out of the carburater at an angle above the flapper. Is this a float adjustment issue? and if so what would be a proper setting? Obviously I will have to get a repair manual on this, but thought someone might be able to help me until i do so.
Re: float adjustment on 1976 mercruiser140
Ayuh,.... Welcome Aboard Deck Hand,.... What tube, Where,..??
Got a Picture,..??
Don S
Is this the tube you are referring to? If so, I would think it's more of a needle and seat stuck open with some dirt or the float failed, probably not just an adjustment issue.
attachment.php
deck hand
attachment.php
Yes that is the tube. Thanks for your feed back I really appreciate it!
cr2k
A new carb kit will have all the specs.
