float setting
rdmcc
having trouble with fuel system on 85 hp force carburetor is float setting 13/32 if so can’t bend tab on float to get that or is set to get a 11/64 drill bit below float an carburetor body
jerryjerry05
Turn the carb upside down, the float should set level with the body.
Turn right side up and the float should drop and almost hit the center post.
Check the floats for water??
