hipster dufus
- Jan 1, 2009
- 169
what do u do when u flood ur engine?i bellieve i flooded it by over pumping my bulb and messing with the choke and throttle. it was bad enough that i could see gas dripping at the carb. i cleaned it up and drained the carb. it started after that and i did not see any more gas leaking. it is a 9.8 4 stroke tohatsu. what is the correct procedure if u flood ur engine? i do run it dry after every use, i usually use it once a week. as always any advice is greatly appreciated. thanks
