sledrescue
- May 5, 2012
- 8
I am in the process of redoing my floor/decking in my 1976 Glastron Carlson CV-16. The old flotation foam was waterlogged. Floor had a couple of minor soft spots. Stringer is fine and solid. Transom is in good condition from inspection.
Question #1. Original flooring was 1/2" thick. I am trying to figure if I should stay with 1/2" or bump up to 3/4" plywood.
Question #2 Should a person install new flotation foam or not? If so, I have heard of some using the pour in expandable foam and others that buy the yellow closed cell foam from like Menards, Lowes, Home Depot and yet others say use a combination of the sheet foam cut down to size and then embed with pour in expandable foam. And then there are those that say don't reinstall any foam.
Question #3. Should a person use a hole saw and put 2 ventilation holes in the floor near the transom and cap them with PVC style unscrewable cap in 2 areas near the transom and 2 areas up by the console. This way a person could force air down into and underneath the floor/bilge area when the boat is in storage. I have blowers to exchange air and dry things out if and when they would get wet. The problem goes back to question # 2 to foam or not to foam. The holes that would be cut would then be worthless if expandable foam was used to core fill the bilge area. And core filling the bilge area right to the bottom of the floor/decking could also trap moisture long term. I want to do this repair right the first time. I like the ventilation idea with PVC screw in caps to be able to vent the area when the boat is not in use. I always store the boat indoors when not in use.
LIKES or DISLIKES?? Opinions or suggestions? Pro and Cons?
