I am replacing a floor in a Blue Fin Spectrum 17' aluminum fish N ski bow rider. This is a first for me so I am seeking advice. I have tore out all of the old floor and removed cushions which were rotten as well. The foam was all dry. I will be applying carpet to floors. Some questions:
What type of plywood should I use?
What type of epoxy/resin?
Has anyone used/replaced carpet with snap in carpet?
How should I join seams?
When tearing out the old floors they were not glassed together or glassed to side boards. Should I replace similarly? Does water just go to bottom of boat and then the bilge takes care of it?
Carpet goes up sides to top edge and a metal trip piece holds it in. How hard is it to remove and replace carpet in these areas and how do I remove the trim strip?
