floor rotting?
huntingtheworld
So i keep having brown stuff seep threw the floor?Do i really want to know what it is. There is a sag on the left side of the deck.I think it was make like that.It is not soft but it has a small thin crack.It is very hard and the boat is in good shape.I washed it 2 times this week.I fished and had to clean it up.and i left it outside to dryout and it started coming threw the floor and out the drain plug.the boat does not leak water any suggestions?I sealed up the crack and thinking about repainting the floor to cure it?what do you think?image (3).jpg
bp1313
Re: floor rotting?
Weird! Hard to tell from the picture. waterlogged wood? Foam? I'm not experienced enough to help, but I'm sure someone will jump on this one :)
mwe-maxxowner
Master Chief Petty Officer
Re: floor rotting?
If there is moisture seeping through your deck, I'd imagine you have problems. My guess is the crack is a seam in the plywood that has busted over time, and the brown liquid is dirty water squirting up from wet foam underneath when stepped on.
I am by no means a boat expert, this is just my guess based on loads of reading and learning on here since I bought my first rotten boat, or two. I'm 3/4 way through a complete rebuild.
Re: floor rotting?
DENIAL - An unconscious defense mechanism characterized by refusal to acknowledge painful realities, thoughts, or feelings.
Once enough people who have experience rebuilding boats see your post you'll get the same answer here that you did in the general boating forum. Unfortunately there aren't any "good" explanations for brown stuff leaking from the innards of a boat.
Looking at the positives in this, you've picked the right place to get good advice should you decide to tackle the repairs yourself. It's very doable, and you'll save a ton of cash over paying to have it done by someone else (plus you'll know that it's done right).
Woodonglass
Re: floor rotting?
I'm trying to understand what I'm looking at in your picture???:confused:
jbcurt00
Re: floor rotting?
Brown stuff coming out of the floor
Not much more info there ^^^, but a few replies......
Hunt: It will help to have a better idea about what the parts & pieces of the boat are called, so a pix makes more sense:
attachment.php
Sounds like it's on the deck (boat floor, also called a sole) along the port (left, looking from the motor forward) side of the boat. So likely this pix is shot over the port gunwale, looking down..
