floor
am
How bad is it when you have a small soft spot on the floor of a bass boat? I know this is probley rot but it looks ok under the carpet, but when a 250 lb. person gets on it its a little soft. What would happen if I dont fix this, and if i do decide to fix it what kind of money am I going to have to spend? Thanks
Boomyal
Re: floor
It will get worse if you do nothing. If the stringers are not currently affected you run the risk, by waiting, that they will be.
sloopy
Re: floor
Is this deck or the hull of the bass boat? From what you describes I am sure it is the deck but when boomyal mentioned stringers I got a little worried ;) <br /><br />If this is a plywood deck, you could can temporally fix it with a new piece of plywood and some new carpet!
