Flowmaster on a Cobra SX
Cobra SX
Hello all, i have flowmaster exhaust on every car and truck i own. Now i want to take it to my boat so i can get power<br />and good exhaust sounds for my - 302 5.0 ford V8 -<br />I have a 95' Sea Swril Cobra SX drive. were should i look for suggestions on how to do this.... thank you
Re: Flowmaster on a Cobra SX
It Ain't Going to Happen...............
ZmOz
There is no place to put a muffler in a boat. It will get way to hot. The water is your muffler. It should already sound good that way, and you would only lose power if you installed a muffler.
outboardguy
In California they are enforcing sound regulations more and more each day.You could go with a thru hull exhaust and use supertrapp mufflers at the end.I've seen a few setups like that and they are alright. My favorite setup though is the silent choice.You get the best of both worlds.Your exhaust can either exit through the prop or through the hull, and it's all controlled with the flick of a switch on the dash.
Sean165
having the boats exhaust come out of the inside of your prop is the only way to go, its reduces cavitation and eliminates the vacumn that would otherwise be there. Hey maybe you could weld a round muffler to your prop..:) JK
Cobra SX
cool thanks guys , think im going to weld one right on to the prop! =)
ZmOz
Make sure you get a stainless steel muffler then...that way it won't rust! :D
