Ive got a 1993 200hp,offshore, serial #OD262721. Do they make a flush attachment so you can flush out while still sitting in the water or on a lift. I know the newer models do.
I have never found anything other that this http://www.mstguardian.com/enviro.HTM Because of the price I took some PVC and made an extension to the hose on the flusher. This way all I had to do was trim the motor up and use the PVC and slide the muffs over the lower unit. I also came in from the prop side because it was easier to push it down then to come up from the bottom. Oh yea one thing is to fine the muffs that have the metal clamp and this way you could bend it just a little to give you an opening to make it easier to start when you side it on the lower unit. The plastic ones clamp to hard and are very hard to use.<br /><br />I hope this helps!!
