enginesilo
- Jun 9, 2008
- 355
So I am new to Inboard/Outboards, but not to Jet Ski's and Outboard Engine's. Do you flush an I/O the same way? I am using the hose flap motor muffs.
1.) Turn on Engine
2.) Immediately turn on water/hose
3.) Let engine run for 10+ minutes, or till the thermostat opens
4.) Turn off Water
5.) Immediately turn off Engine
Is this the best way to go about it? I know that people say that if you run an I/O without water the impeller will burn up super fast. Should I be turning the water off and then the engine immediately afterwards? Can the engine actually flood if the hose was left on without the engine running, or does the water not filter through the engine like that? I know that with a jet ski the hose can't be on without the engine running to be safe. Want to make sure I am doing this right so any tips will be appreciated.
1.) Turn on Engine
4.) Turn off Water
