Flush Plumbing Retro
Hook'd
Hi folks, I'm gonna plumb in an engine flush line, and need some advice. What is the ID of the raw water pipe feed (DPA)? Any advice on where to get a tee fitting for this (fresh water from transom fitting to raw water line)? Type and material? Other advice?
Thanks,
Thalasso
Well a good start would be, just what is the engine and year?
1-1/4"
however why not simply use the muffs?
Hook'd
Thanks Scott. Muffs just seem like a hassle when I'm using the boat a couple times a week. And each time I worry I'm getting enough recirc. Maybe overthinking?
Do you use muffs on yours?
