Flushing Alpha One trim fluid?
Randal106
How whould i go about flushing, and re-filling the Power trim fluid? the fluid is a milky pink, and it should be red correct? also, what fluid do you reccomend to fill it back up? Can you use tranny fluid?
Thanks
Re: Flushing Alpha One trim fluid?
ATF is 1 of the many recommended Oils,.......
I'd say that's what your's has in it,... Hence the Reddish Color......
Use a small Pump to remove the oil from the Res.,....
Then Refill it,+ Cycle it,.. Repeatedly.......
If it Pinkens again,..... Do the Same Thing, Again till it Stays Red..........
Randal106
Ok, thanks for the tips, what i did is i removed the two lines on the Outdrive, pumped out the Res. with a hand pump, filled it with, ATF and flushed the fluid out the lines on the outdrive, it worked pretty well, and there was only a little pinkish tint after all was said and done, ill have to do it agin later to get the rest out.
bosavy
it can be getting air from pump or cylinders just keep a eye on them
