My son and I have an ongoing argument. We have a 2003 40 hp Yamaha, It runs beautifully. I recently bought a waterfront lot. I want to keep the boat in the water since there is no lift. I think if I flush the engine out with freshwater after each use, by using the hose connection on the side of the engine and do not run the engine, it will rinse out both the engine and the water pump. He was told that the engine and water pump can only be flushed out properly if it is running and being fed fresh water to the foot with the earmuffs. We need some expert advice since I intend to leave the boat in the water for the season.
