Flushing the motor
Btrent1999@gmail.com
Hello I have a 97 120 HP runs great good Motor I was just doing some research on some of the threads on here I was seen a thing on maintenance about flushing the motor I haven't been doing that I would like a little help on Flushing The motor I'm suspecting just flush it with the muffs on it that's right not appreciate any help thx guys
Simple_Man
If you use it in fresh water, no need. If you use it in SALT water, hook up to the muffs when you get home and run it for a few minuets.
jerryjerry05
Running in sand/mud salt water etc??
Then flush.
The motor needs to be brought up to operating temp so the thermostat opens allowing the water to flush the system.
