fly wheel removal \ 1st time
bigwhistle
have a 1957 35 hp. evinrude lark<br />can anyone tell me is that flywheel pressed on ?<br />can't get it to budge.<br />has to be removed for tune up motor has not ran <br />for 10 yrs. +<br />all help,advise,free manuals,part diagram,would <br />be most helpful, that you very much <br /><br /> 1st time mechanic
akriverrat
Re: fly wheel removal \ 1st time
the crank has a tapered shaft and locator keyway. i had a 56 18 hp from 1971 till 1986. never could get flywheel off. just kept running and hoping points wouldn't fail.
flashback
have ya tried a wheel puller? JB will move this post to outboards..........good luck
Mod2
Moving to Outboards.
Paul Moir
You need a device called a 'harmonic balancer puller' avaliable at auto supply stores (I paid about $15 cdn for mine). You remove the manual pull start (if you have one) and then remove the three bolts that hold the 'gear' the pull start engages. The puller attaches to the three bolt holes (with long bolts) and has a long screw that pushes on the crankshaft. Sometimes it is necessary to tighten and then strike the screw to free the flywheel. You'll see what I mean.<br />Any form of puller that grabs the edges of the flywheel will probably destroy it.<br />When installing the flywheel you need to torque the bolt to 105 ft/lbs. Any less and the flywheel key will shear & throw your timing off. You'll need a strap wrench or something to hold the flywheel from turning while you do this.<br /><br />Hope all this helps!<br /><br />EDIT: oh, one more thing, the three bolts that screw into the flywheel are 1/4"-20's (Quarter inch-Twenty threads per inch). If your puller doesn't come with that size, you'll need to buy some.
Tinkerer
May not apply to your motor, but if you're going to strike the puller centre bolt, make sure it doesn't have a point that can fit inside a recess on the crank end and spread it when hit. You can break the thread end off and maybe need a new crank if there's not enough thread left.
Scoop
The harmonic balancer puller works well. If you have a friend that has an pneumatic air wrench, I heard that using that will get the nut off and will loosen the flywheel. <br /><br />Absolutely do not use a puller that pulls on the outside of the flywheel or you will damage it.<br /><br />If you do have to strike the crank, make sure you are careful not to damage anything. A good way to get the nut loose on the end of the crank is to put a box end wrench on the nut and hit the far end of the wrench with a hammer. It does a great job. <br /><br />On other tip. Make sure the shaft of the crank is clean and has not grease or anything else on it before you reinstall the flywheel or it will go on too far and you will have trouble next time or even before. Good Luck
SeaMasterZ@aol.com
jeeze .. and I was going to ask, wouldnt it be a good idea to put some never seize on the shaft so it DOESNT get stuck again :eek: <br /><br />so much for that thought!<br /><br /> :rolleyes:
SeaMasterZ@aol.com
iboat has manuals for sale, I went with amazon.com cuz they offered FREE SHIPPING (ya hear me iboats???)<br />on purchases over 25 bucks ... and being the type that I am, I got both seloc and clymer, I dont want to miss anything, lol<br /><br />if you are going to keep the motor, and larks are little jewels, great motor once you get em squared away, GET A MANUAL<br /><br />its yer best friend!<br /><br />next to iboats that is :D
